Frein
SBS, Spanish Brake System par FlyBikes
A new brake mounts system called SBS (spanish brake system).
We wanted to design a system where you can put and remove your brakes quicky and easy. For brakeless riders, You might get to a spot like the trails or a street spot where you need brakes so you can put them on without the hassle. If you ride with brakes and feel like riding without them, you can also remove them easy and quicky. Putting on and removing them takes even less than 1 minute.
A voir là : http://www.vimeo.com/6296984
http://www.flybikesbmx.com
Mouai, faut pas que ca prenne du jeu quoi, sinon c'est sur que pour passé en brakeless c'est plus zoli, le principe st amrtin et autre est deja pas mal sinon.
